bigone5500
I'm assuming all I need to do is crimp a female terminal on one wire then two male ends on two other wires. That is straight forward. But connecting the three wires together, I'm assuming, is as simple as soldering the like colors together and applying heat shrink. However, I have had the idea that I can crimp a female end on a single piece of wire, then take another wire and crimp male ends on each end. Then strip off the insulation from the center and solder the female wire to that. The only issue with that method is re-insulating the solder joints.
In short, what is the best (and most reliable) method for making this type of connector?
