Capn Pete
I have my Devo7 TX set to factory settings. I notice when I throttle up, it has a tremendous amount of negative pitch till about mid stick. Then it's only moderate positive pitch till 100% throttle. Am I right is adjusting PTCRV to address this pitch issue? It was set at -15% at P-L. The others are INH till P-M.
Would it be better to have 0% at P-L and maybe have a little positive pitch at P-1 or -2? P-M is at 25%. Should I raise that a bit so it doesn't just jump up when I get above mid stick? P-H is at 55%. is that enough to get it off the ground easily?
I'm not looking to do 3D right now. I just want to get it airborne and fly it around for now.
