Lol. Just started the build. I have only cut 1 bit of woodDepends on the charge rate that you are putting into it. If you are just doing a 1c charge rate, it will take the same amount of time as a $40 charger. However, if you are doing 4 at a 5c charge rate, it will be much less time to charge, and you will be getting multiples done at once. so, it's all based off the charge C rating of the battery.
WE NEED AN AFTER!!!!! DO IT NOW!!!!!
That's really starting to come together!
Rc-hero got a good stock of Ichargers back in, and good prices as well Graham.
