I upgraded my Naza M V1 to a Naza M V2 and before and after the upgrade I only had motor #1 to start up and run. I thought it was my PDB and after replacing it I still get the same thing. If any of you guys have a naza post some suggestions on how to determine if it has gone bad or something. I can get each motor to calibrate and then startup and run like normal using a "y" connector to the throttle on my rx but when I connect the servo leads to the naza I only get motor#1 to run.
