ok, so I did all the things I set out to do.. re-programmed the ESC, and took it for another maiden flight on the back deck... was dark out and I needed the deck lights.. spun up really good, and was then trimming up the controls.. had the rudder under control, and proceeded to up the throttle.. got about 1.5 inches off the ground and got close to hitting myself.. re-positioned, and tried again.. this time it was all over the place like my control inputs did nothing for the swash control.. so I set it down.. checked my linkages, and tried again.. this time I gave it 50% throttle waited for the head speed, and motor to catch up.. once it got a bit light I tried rudder inputs.. it spun.. then when trying to stop the spin I over-corrected and the heli went tail first spinning wildly into a pressure treated 4x4 post... the post took some damage, but the rotor blades were cracked near the head.. the flybar bent, the feathering shaft bent, the main shaft bent.. and I killed the counter rotation shaft (the thin walled piece of tube that connects the main gear with the counter-rotation gear, and 2 of the ball mounts that are attached to the blade grips, the threads broke off in the grips (can possibly drill out)
luckily I have most of these parts on hand.. feathering shaft, main shaft, flybar shaft,.... only parts I need to get are the rubber bushings or dampers on the feathering shaft (the crash destroyed 2 of them somehow...) new blade grips, and that piece of the main gear assembly... might make a trip to ray robbins tomorrow.
