Nasty, cold, rainy day today. Desperate for something to do, I started pawing through my jun....uh...."spare parts" to see what I could come up with.
I do a bit of modeling in brass, mostly farm toys, so I have a good stash of brass.
I play around with Arduino projects and have bought 3 or 4 $5.00 Goodwill printers and stripped them for parts so I have a good stash of gears, shafts and motors.
I also have some benchtop machining equipment from Grizzly:
(Hey, I'm easily bored, I need lots of diversion...)
So after a little head scratching and playing with my toys, I came up with this:
.125 brass rod for the main shaft, threaded 3mmx.50 on one end.
.125 ID brass tube inside both ends of a larger piece of brass tubing for bushings.
.375 brass rod bored .089 on the motor end and .125 on the prop shaft end for a coupler, with a 3mm x .50 set screw.
Now I just need to build a boat to put it in...
