in one of Tony's vids, about charging lipos in parallel, it looks like the two para boards are daisy chained without having to tap into one of the 6 main and parallel slots on top of the board, if that makes sense. it looks like there is a direct connection coming out the back of one board, and the second one ties right into that. same for the second parallel connection.
it is hard to tell by looking at the picture, but does someone own this para board, and know if you can tap into it from the side or end with out using up one set of the 6 main and para slots on the board? :
Hobbyking Parallel charging Board for 6 packs 2~6S (XT-60) (AR Warehouse)
if not, is there one i could get that has this feature. i'm looking for one that has xt60 connectors.
thanks,
pat
thanks,
pat
