Ok, maybe that wasn't so bad. I was just throwing a fit because I had to do the calibration again.
But...I don't understand how the new Governor is setup. There is no spot to set the head speeds. The way it was, before the change, I could set normal mode to 1500rpm, IU1 to 1750rpm, and IU2 to 2000rpm. This new version only seems to have a spot where you can enable or disable the Governor, a single rpm setting, and the sensitivity.
Other than the issue with the Governor, I don't mind the change. Has anyone played around with the Governor, after the version change?
How did you guys get the update? I was on it last night and did not get an update popup. I have mine set to update on startup. I even clicked on update in the system menu to add a new heli and nothin'. I checked the web site and it shows the most recent update to be q, which I have......
Hi Guys I went on Phoenix and it updated to q and said there are no more updates?
