My how my mind changes. I was cleaning the work bench and area today. Saw the old seahorse case on the shelf. Pulled out dusted it off opened it and cleaned it out.
Not much was in there just some dirt and dust from sitting around. Oh I that plastic primer for adhesives is peeling off. I don't think I preped the plastic well enough for it.
I have some sub floor (1/4 in luan) from a house I did a few years ago. I don't remember which job. Anyhow it was big enough to cut down to fit in the seahourse. It took a bit of time to get it to fit and look fairly decent around the edges. The bottom of the case has four lugs molded into it. These lugs are around M10 size based on the tap I have. I didn't tap it yet but I am going to, I think. I don't know if I want to tap it or use an m10 with course threads for plastic. The base plate needs to hold the weight of the power supply. What I am not sure of is how to secure the power supply. I have see people use use 3M grey and it help just fine. That stuff is rated at 35lbs of holding. For now I will keep the free wood but when the money is there I will upgrade the wood to either ash or oak ply. I am thinking oak with a gloss finish. High gloss finish.
The PL6 a.different story. I may have to cut a channel in the base to accommodate a "leg" that's on the back end of the charger. Thus leg stretches the width of the unit and give a tilt to it also. If the channel idea works it will allow me to mount the charger with 3M grey also.
Now for the fun part. So the discharger is needing to be finished. I figured I would cram that into this case also. Oh I got a large Seahourse won't be any issues for room. I have mounted the trim lots to the deck. I have to work out the resistors. I have to solve how I want to mount them in the case. I need to be able to move a lot of air for cooling.
Since ill be adding 4S packs to my rig I will need to test out the bank be for committing it to the inside of the case. My big issue for heat is with the 6S packs. I really need to do a seven or eight resistor load for 6S. That way the resistors will be able to handle the watts better. If I was to change my load bank in would go 8 8 ohm resistors in case any one wants to know. That's for a different article
I need to plan the arduino install along with the screen. See I still have the code base. Which more than likely I don't when I will need to down load the backup from Google drive. Which means I need to re download the font file as well. I will have some time ahead of me to solve these issues.
I will get a pic or two tomorrow after a get a few more things together on the case.
