Hello Again
Quick question.
I typically clean off the surfaces of things with rubbing alcohol
prior to placing 2 sided tape to something.
In this case I am wondering if I can do so on a
flight controller board, more so the KK2 board?
I want to place the board back onto the frame using
2 sided foam tape but I am curious if rubbing alcohol
will harm the underside of the board.
Now I do not plan on soaking it just enough to get the job done?
Hello Again
Quick question.
With that being said...sorry full of questions
Instead of the standard 2 sided foam tape could I use the
sided velcro on the board?
This way it would allow for easy removal.
My only concern here is that 2 sided velcro has alittle
give to it which may cause the flight board to be a bit out of level?
Not much I am sure but that would be the only draw back? Thoughts?
