VTX Runcam Split 2 Issue
Yes, that is the correct pinout. I don't like positive on the outside, but is what it is.
Then it will be uart 1 I think. Been a minute. And make sure you are powering it from the 3.3 rail and not the 5v rail.
bigone5500
I moved the wire from RX1 to RX3 and set uart to 3 in BF. The sat still doesn't bind. I get a short blip of the led in the sat when I power it.
bigone5500
It's DSMX and I'm using set spektrum_sat_bind = 9. Then save and it reboots. I think the sat should flash when it is in bind mode. I checked the power and I am getting 3.2v.
If these uarts behave the same way a USB COM port in Windows does... then the number in Windows may be assigned dynamically when they are plugged in. If so... then when you plug in, you'll hear a notification sound and the device should show up in device manager and tell you what port number that was assigned to it.
If they don't behave the same... then just ignore this post
bigone5500
Actually the usb in windows is working. I can connect the FC. It's the satellite Rx that will not bind through the CLI command.
