bigone5500
Is there anything I can try to get this servo to center? If you look at the first photo, you can see two 'pins' that look like rabbit teeth resting on the gear to the right of them. These two objects should be inline with the shaft that the last gear is on, down the length of the servo. The last photo shows the location the pins should be located if it is properly centered.
![20171212_165655.jpg 20171212_165655.jpg](https://www.rc-help.com/data/attachments/15/15187-f3b6016bac81fa9fc37550df35df5bbb.jpg)
![20171212_165637.jpg 20171212_165637.jpg](https://www.rc-help.com/data/attachments/15/15186-cbbe8b8e3a26ff491fc5572b1365cb76.jpg)
