PancakeMSTR
Hi,
So I recently got back into RC helis and I've been trying to setup a Trex 250 I had previously built back in like 2013 or something.
Mainly, I converted it to flybarless with the Ikon 2 FBL controller. I also bought a new transmitter (FrSky Horus X10S Express), and replaced the receiver with an X8R.
It's been a...journey... but things have actually gone reasonably well up until now. I've finally started flight testing the bird, and unfortunately I'm getting excessive tail wag for no obvious reason.
Here are things I've tried
Here are things I'm planning on trying
Lastly, tail wag aside, I have two questions about setting up the Ikon that I've been unable to answer:
Hope that is enough information! But obviously I'm happy to answer questions and try recommendations. Thanks for the help, and excited to be back into RC!
- Tightened tail rotor assembly so that it wasn't free to rotate about the tail boom (yeah, it was loose).
- Replaced shot-to-shit 42 mm blades with brand new 37 mm blades.
- Replaced the very sticky (would barely slide along the tail shaft, maybe the grease went bad?) micro heli tail rotor assembly with a nice metal align assembly that is nice and smooth (by my standards).
- Played around with Tx gyro gain.
- Spooled up Heli on my desk (yes, seriously) and watched for vibration in the tail. Did not see any, but was hard to tell through shitting my pants.
- Set ESC (Align RCE-BL15X) BEC to 5.5V and 5.0V (I've read in various places that this has helped).
- Replace the Align DS420 tail servo with a KST DS215MG (I've already done this, gonna flight test it this morning). I just flight tested the new servo and it actually seems to have helped quite a bit. There is still a small, high-frequency vibration in the tail that I'd like to fix (any ideas?), but it's definitely an improvement.
- Play around with Ikon PID settings?
- Other recommendations?
- I have my ESC (http://www.align.com.tw/ManuaLib/Heli/esc/G20310-RCE-BL15X_en.pdf) setup in Helicopter 2 Mode (Soft Start + Governor). My impression is that, in this mode, the ESC attempts to keep the motor spinning at a constant rate, and that's what you want for idle-up flight. So how should I configure the "Throttle out & Governor Setup" page on the Ikon? It's not really clear to me what throttle out is or the relationship between the Ikon and the align ESC, or in general what this page is supposed to be configuring. Can anyone help out?
- My other question is about swashplate setup. You are supposed to set Cyclic deflection to 10 degrees, but I'm not sure where or under what conditions I'm supposed to set that angle? It's not well explained.
