Unless we are talking about the Castle Creations Ice lineup hahahahaha. V1 that is lolbut the CC's quality is top notch
I found these instructions on Castle's website for calibration of their ESC's. Hope it helps.
TECH TIP: Castle ESC Calibration - when, why and how. — Castle Homepage
I have had this calibration issue with castle as well. Can't for the life of me remember what I did to solve it.
Okay so the throttle channel on the Ikon seems....messed up somehow? What I've done is plug a servo into it. Min to Max throttle moves the servo about 1/2 or 1/4 of its total travel. Also at Max throttle, the servo is sitting at mid travel. This seems wrong maybe? I'm not sure how to fix this though.I have had this calibration issue with castle as well. Can't for the life of me remember what I did to solve it.
It is. I think I might have figured it out. It seems like the throttle out settings were really messed up. Let me give it a go I'll get back to you.check your throttle curve and make sure it is linear.
return your throttle endpoints to 100%, or better yet, start with a new model in your Tx.
point the blades front to back inline with the tail boom, and the nose facing you. Put a pitch gauge on the front blade so you can read it, then adjust the cyclic throw to 10º. It should be the same both ways with the same setting on the other way. If it's not, recheck your setup to make sure everything is equal.
No worries, things like this we take for granted once we learn them.I hate to be...thick...but can you draw a picture?
