bigone5500
OH MAN!!!!! I tried a different SD card and renamed the .bin file by adding a 1 at the end of the filename. I plugged the card into the printer and about 10 seconds later I got a screen stating Ender 5!!! YESSSSS!!!!!!
So how do you like the CRtouch?I did not have to repin anything on mine, it was a direct swap. In fact, the plugs almost ended in teh exact same place, with the exception of the extruder fan. That plug is just slightly off.
I did not purchase the one that you purchased, I actually went out on a limb and purchased the touch screen combo. There were only 4 reviews and most were bad. But, it's amazon, if it doesn't work, I get my money back. Well, I installed it, and it just works (after I located the correct firmware that is). I also put the CR Touch on there as well, which OMG... I should have done WAY sooner.
I did get the dual drive extruder as well, but took it off since the ratio is so far off, and it was digging into it's own body. Below are all of the parts that I have put on it this time.
Amazon product
Amazon product
Amazon product
Don't buy this
Amazon product
