Capn Pete
I have an X6 drone by Oksale. GPS picks up 17-18 sats and has been working fine till a couple days ago. Return to home, headless, auto takeoff/land and follow me all worked fine. Tried the circle me function for the first time and it worked well too. When the battery ran down and I restarted it with a fresh battery, I got the toilet bowl effect.
If I turn off the GPS, it tries to run backwards and to the right. I figured the GPS is trying to correct the trim problem. When I click GPS back on, it toilet bowls. There are no sub trims on the TX and it toilet bowls so badly I can hardly land it without cracking up. Till I ran the circle me function, it flew fine. Could that function have 'stuck' and causing the mal func? The only thing I have not tried to taking the batteries out of the TX. Do you think that will help or do you think it may be the board?
I am bewildered.
I am bewildered.
