It does make it more stable, IF, you have a stable hand. It also makes it QUICKER! And at first the sound is very intimidating.
I gotcha my friend... Oh yeah and you probably noticed in video I didn't hit iu either... lol I knew it would be ok I just wanted to hover in normal mode and be comfortable with thst first
The vibes, for being on a helicopter, were actually not that bad. But, next time, strap it down even tighter and it will help. Might need to, depending on the type of camera, open it up and put a little hot glue on the lens to keep it from moving. Great video though.
Awesome videos buddy! Very nice!
Going to IU1 will do exactly as what has been said....more stable but also quicker to react to the stick inputs. There's no rush but when you feel that you want to try the Idle Up, maybe just set your Idle Up curve for 10-15% more than your Normal Mode curve. I think I remember you saying that your throttle curve, right now is 60 or 65 from mid stick and up. So, make your Idle Up curve 75,75,75,75,75 or even 80,80,80,80,80. This slight change will gradually get your use to the higher headspeeds.
For me anymore, I just use the Normal Mode to get the helicopter off the ground and then I do my Sport flying in Idle Up 1 and any mild 3D in Idle Up 2.
Nonetheless, you've improved greatly over the past few weeks. Congratulations!!!
of course it's feasible...it's your helicopter. Fly it how you want it. Go ahead an set the Idle up 1 so that you have a flat 75-80% throttle curve and then change the Idle Up 1 pitch curve to whatever you have for Normal Mode. Since you aren't interested in 3D flying, don't think of the Idle Up switch as "3D only". Lets just think of it as a "Flight Mode" switch....this will just give you a bit more RPM and still have the same pitch.
No worries!!!
What are your Dual Rates and Expo's set to for your cyclic and rudder?
Cool! With those Dual Rates, there shouldn't be much of a surprise when you flip the switch. Just spool it up, come off the ground and into a controlled and comfy hover (preferably with little wind and a bit of altitude, for the first time). Don't be surprised if you get a bit of tail wag because the higher the headspeed, the less gyro gain you will need. If you do get a bit of wag, just lower the gain by 5% increments until the gain is gone...shouldn't be much different, but there will be a difference.
Just take it easy at first with some altitude, listen to the change in RPM, feel the difference in stability, and have fun with it. If the change in RPM or sound is too much for you, don't be afraid to go back to Normal Mode flying.
Nice drive video, Tony! But....you're driving on the wrong side of the road, lol.
Videos are looking good mate.
Looking good, Tony - keep it up! Btw, did you fly behind yourself (around yourself) in one of the previous videos (post 34)? If that is the case, I will strongly advise against doing so for safety sake
