Have fitted the servo, and it's wicked, it must be said, fast as hell. You give an input and it's there before you finish the input, it's all set up and working correctly, but needs tuning, have had a quick hover, and taken the gyro rate up by 20% but needs to go slightly higher, where I had a wicked wag going into IU 2 95% throttle now I have nothing and this test was before doing anything with the blade grips.
That leads me on to the next job.
Replaced one blade grip bearing and washer with the pre load kit and and dual bearings, it's taken most of the play up, so hoping that it will greatly help dial in this tail, just need to finish the job,
