Hello all!!!
I followed the steps of the video 7 (Align 450 Pro V2 3GX Build Guide Part 7 Basic Gyro Setup) and I will try to explain what is going on.
When I do the first step of the Gyro setup (elevator endpoint setup) and press the button again on the 3GX and turn the helicopter to check if the gyro is only on the elevator, I see the pitch and aileron moving, but in opposite directions. When I move forward, the elevator goes down, aileron goes down and pitch goes up.
When I use throttle cut and move throttle forward, same thing, elevator goes up, pitch up and aileron down. I tried to invert the aileron on my DX8 but was even worst.
When assembling the servos, was there a servo assigned for each of them (aileron, pitch and elevator)?
It seems that one of them is inverted.
Please guys I need help to try to sort this out.
Thank you.
Thank you.
