Prop two basic questions here.
idon'tknow!
rc-help EXPERT.......????
question 1 what electric motor would i need to make this electric?
question 2 does this look like somethings missing?
thanks in advance for your time... sorta looking to make this bird electric... but need to know what size motor, and also if everything for it is there.. oh yes the engine is a 40 size if the photo is tough to see.
idon'tknow!
Thanks tony, doesn't look bad at all at least on the price front... the wing span is 4'10"... and in case it helps heres the fuse length 3'7" thanks for for the help!
treff
The missing something seems to be the centre section of the fuzz over the wing. It will fly without it but looks better when fitted.
Cheers
idon'tknow!
that's what i thought to... the plane seems to be scratch built and the person making it seemed to want the wing to come off, but it seems that when the plane was made the guy forgot about that part. If I had planes for it I would make a new balsa cockpit, but since I don't, it is going to be tough... not sure what to do.
treff
It would be easy enough to build one out of balsa and cover with whatever material goes with the plane. Have fun flying it which ever way it goes. Cheers.
