General UMX Carbon Cub Set-Up w/DX9
mrsr71
Hello,
I’m trying to figure out how to set-up my UMX Carbon Cub SS on my DX9. I’m having a heck of a time. Can someone help me out.
Thanks...
Since you didn't specify exactly what you are needing help with, I suspect starting off with a general radio setup would be best to give you somewhere to start.
Here is a little more about the radio...
If you view those on Youtube, you'll get the full list of DX9 video's that Tony did.
Are you a Mode 1 or Mode 2 flyer, I have DX9 SPM file for the Carbon Cub Mode 1, I could send you.
If your Mode 2 It would only confuse you, however a bit of advise, with the Flaps only set minimum throw, because the Cub is so light the flaps are super effective 5 to 10 degrees is heaps.
Your welcome to try, if it doesn't work just create a new model and start again.
  • 018~UMX CUB.SPM
From what I'm reading it should work OK the changes are already made by you Tx being set up as mode 2
