I have a Lumenier TX5G6R mini 600mW VTX that the solder broke away where the FPV antenna connector is soldered to the VTX . I was wondering if anyone had any luck soldering one back together and actually working again?
As long as the pads are not damaged, it should be pretty straight forward to put it back on. If the pads were damaged, there is a little more work involved, but it can still be done with new wires to attach the traces that are missing.
