Thanks for your reply. I was kinda leaning that way and was hoping that was right as I had already purchased them! Very new to all this. Just read a post regarding the 'feathering shaft'. What is that? Where is it? What does it do?Walkera don't give much in the way of specs, but as close as I can work out 7.6-6 servo are Analogue & plastic gears and the 7.6-9 servo are Analogue & metal gears. They should be interchangeable but if it on the cyclic you should change all three.
So it's located in the rotor head and I'm assuming is easily damaged. What are symptoms of a damaged feathering shaft?Hi Capn Pete, the feathering shaft basically hold the two blades together while allowing them to rotate in opposite directions in a CP (Collective Pitch) helicopter.
This is the feathering shaft on an Align 450L, if your going to fly CP Helicopters you will soon know all about feathering shafts and how to change them with you eyes shut, you will change so many of them.
Aha. Can do. Dunno how I would've gotten that info without you. Is blade tracking when each blade follows same horizontal arc? Thanx. Sorry for so many simple questions. Am really new to this.Remove one blade and use a Hex drive to turn the hex nut clockwise the remaining blade will stay stationary if the shaft is OK or will move up & down if the shaft is bent.
A bent shaft makes it impossible to maintain blade tracking.
Thanx, Admiral. Really appreciate help. When I first started, I didn't know where to ask questions. Site where I bought from were useless. As I like to say: " When I first started, I knew less than nothing. Now I've learned so much, I know next to nothing!"Correct ! Don't apologize for asking questions, that is what this site is all about.
There is a Library full of "How to Videos" that may also be of great help to you on this site.
