Chargers Will the B6AC cut it?
callsign4223
I have built the computer psu power supply for my charger. Having done that, I would suggest going with Tonys build on this. That's because using the server psu is easier, with more power, and simpler. You can get these server psu on eBay for less than $20. The only reason I used a desktop psu was because it was sitting in my closet and I ended up spending more at radio shack to get it working right than to just get the server psu.
Slobberdog
The biggest reason for using the hp server supplies is their robustness, yes they are easy to modify to use, but these things are designed to be on continually 24-7 for years.
I was apprehensive about pulling one apart but Tony convinced me I would be ok to do it so I tried, and it was really straight forward, I watched Tony's video and read Gaba's article, both brilliant by the way, and it was then an easy task,
