In this video, I walk you through the rudder setup menu. If you want a stable and solid tail, then pay close attention to these steps!
I also talk about the Delay setting and how to use the software to get a perfect 0 delay setting!
I also show you how to set the Anti-Torque Compensation in the gyro which is a MUST. Depending on what position you mount your gyro in, you will set the compensation accordingly.
