Micro 150 Drastic Action:)
danhampson
Good luck mate. I love mine. They are great when they fly right. Mines been crashed loads of times, I would recommend getting a carbon main shaft it saves a lot of messing around when you do crash as I think the original ones are made from chocolate
EyeStation
Everything Bind ok? Sat and RX?
How about servo movement?
Those main motor wires have to be connected as a pair at the terminals, 6 wires total for the 3 pins. Make sure one of the pair did not pop out during soldering or crack from movement.
Lower your trim tab down all the way and make sure you didn't reverse the throttle channel.
danhampson
I had that issue what I did was lower the end point of the throttle until the ESC armed. For some reason the mrs doesn't see 0 throttle (dx6i)
Graham Lawrie
:) Excellent lowering the throttle did the trick:) cheers guys:)
NNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!
BACK BEEPING CONSTANTLY AGAIN AND MOTOR TWITCHING!!!!:(
Graham Lawrie
Everything else is working:) i am really confused now, it has started beeping again!!!
Graham Lawrie
Well this heli is going to be the death of me:(
I plugged the main motor into the tail motor plug and it works fine??
I think i am looking at a replacement MRS board unless anyone knows why the motor will not initialise???
