stokke
i am confused![]()
What was your question again?
i am confused![]()
You will insert your bind plug into the AR6210.
Are you getting lights on both the AR6210 and the 3GX module?
ok i connected the battery out from 3gx to the RX no power, but when i connected the satellite to my AR6210 then the power came in. ok now i have both 3GX and RX power.
If you didnt do the jumper like i said it is not going to work
Jumper?
That's good to hear sparrow
I don't know what Super Bad is on about...
Don't hesitate to ask if you run into more trouble![]()
thanks for this stokke. what's next?
The normal rx will not power up with out the junper from the 3 gx
if you dont power the rx it will not work this is a must with the 3gx and a dx6i
it cant be wired right if the 6210 is powering up with out the jumper there is nuthing going from the 3gx to the 6210 that will power it
... in this video at 06:12 when i press the set button to do the elevator reverse the light turn red not green and also the aileron reverse the light is turning red.
The jumper goes from the 3gx battery/bind port ti the rx on one of the ch so it can power up the leed come with the 3gx but no were in the manual tells you how to do this to make the dx6i work the rutter gain this is how i found how to do it with a 6 ch rx insted of like Adam did with the ar 8000 the way i did it is the sane as a esc pluged in to the rx to gain powerit cant be wired right if the 6210 is powering up with out the jumper there is nuthing going from the 3gx to the 6210 that will power it
