Dennis,
I just skimmed the post but all seems sensible enough... However if you want to run 1900RPM then you dont need to change anything. 1900RPM is within the operating range of a standard 12S setup. I get 7 minutes out of my Trex 700 as standard.
Reducing cell count doesnt in itself give longer flight times, what gives the longer times is reducing headspeed. There are a number or ways to do that other than lower voltage batteries.
If you went down to 6S on the standard motor and gearing then with the added weight of a scale body you would probably struggle to get off the ground. Also if running genuinely low RPM (like 1600 and less) you would want to change the tail ratio as mentioned in your post, but it's not a simple job, you need to slot holes in the frame to fit the 21t gear and stiull have the mesh correctly adjusted.
For moderately low headspeed (1600-1900RPM) you could look at using the Align 800MX 440Kv motor.
