Some slight transient vibration as she gets up to speed is normal, though if it's bad that's something to be concerned about. I'm assuming you have adjusted the grips so we can rule that one out.
Other than that it's back to the point I made earlier. If you are using 'the dreaded normal mode' then when you move the stick down to kill the throttle you are also applying negative pitch. Too much negative with the heli on the ground can sometimes cause problems because the blades can swing down in their grips.
The simple fix is not to use normal mode at all. Just use all idle up flight modes starting and stopping the motor only with the throttle hold switch. Blades to be held near zero pitch during spoolup and spooldown. If you insist on using 'normal mode' for some reason then make a pitch curve that only has a couple of degrees negative so as to avoid spooling up or down with large negative pitch angle applied.
