At last the problem is solved
Finally after 5 months i have found the problem of the vibration.
To recap, i changed everything you can on the heli that would cause vibrations. Tail assembly at least 3 times, different shafts, tail grips, hubs, belt tight, belt loose, drive gears, main gears and finally the motor.
The motor did have a bent shaft which wasn't helping the vibration problem, but it wasn't the cause.
The cause was..............Carbon boom!!!! Can you believe it??? all this time and it was the boom.
I guess the carbon amplified the vibration at a certain frequency. But with the aluminium boom, nothing???? not a peep from the tail. Smooth as a babies bottom.
Did a quick test on my roof but i will have to wait for the maiden flight as the wind is back for a few days.
Looking forward to finally getting my 450 in the air after 5 months.
So today all my birds 450, 500 and 600 are flying. Lets see how long that lasts
