If i read correctly;
The tx should be on ID1 (idle up)
then put the stick at mid point. ( set the ID1 pitch curve to: 0, 50, 50, 50, 100: temporarily)
on my radio I can set the pitch for throttle hold. When I put the radio on throttle hold the pitch curve is the sane as ID1. When I go into the pitch curve I turn on throttle hold and the pitch settings are there. I set it for 0, 25, 50k 75, 100.
then put your stick to mid point
insert servo horns at 90 degrees to body/linkage
