Get a main gear with a higher tooth count. Will have less effect than a pinion change, but it will help. Can also switch to a lower reving motor.
As for gov gain adjustments lowering or raising headspeed. They do not. They will change how aggressively the gov will increase or decrease throttle to achieve desired headspeed, but changing those will not lower or increase steady state headspeed. To change headspeed with a gov you have to input a different desired headspeed. If it takes 60% throttle then that is what it takes, gov or throttle curve doesn't matter.
