Thanks stoke and Slobberdog, pvolcko for the mails. Firstly the washer that goes between the bevel drive and the main drive is correct. It is the only one of that size in the kit.
Before fitting the bevel gear turns freely on top of the main gear. The problem arises when the M5 bolt is fitted through the main shaft to secure the bevel and main gear assembly.
The bolt slides through very freely but with the slightest of pressure on the nylon nut to pinch it tight then the bevel gear will not move freely so something is not right there.
The other point is when securing the bevel gear to the gear hub. I did not over tighten the screws, they are snug with loctite applied to the threads.
If I leave out the washer from between the drives everything works fine and the bevel gear spins as it should but still the bevel gear shatters so I really am at a loss.
The next point is the gain set to high. No it is set to be enough to stop tail wag.
What I have noticed and do not know what this points to is that this helicopter does not like low head speeds. I have to run at 90 percent to stop the
tail going up and down but I think this is a poor bearing in the swash. At very low speed the swash moves from side to side but I think
this is another problem again
Quick update after watching big pops build. Yes it is exactly the same problem. So I need a new shim but I think there is more going on than that. The
kit is plagued with problems and flaws which need sorting out.
Thanks to all for the interest. I have now sent pictures to Roberto the designer and also to KDS in the states and await an out come but
I am not holding my breath.
