Putting the Gyro in the Tx to 70 means you are now in HH mode, it has NOTHING to do with where the gyro is mounted. Above 50% is HH mode, below 50% is Rate mode. If the light changed from red to green when you set it at 70, then the light will change color when it switches from rate to HH mode.
