I think I'm done with the setup.. Is there a way to tell? The settings I'm not sure I got right is rudder endpoints and governor.
Also, both satellites are blinking, is this expected or should there be a solid light? Anyways, I spooled up on the floor and it seems very stable so I guess its time to take it outside. Any final tips before I go out and fly this thing into the ground?
To the people who helped me with this build, especially Tony and Marius: THANK YOU!
The blinking lights on the Satellite Rx's means the Tx lost bind to the Rx. Meaning you unplugged the helicopter and left your Tx on then plugged the heli back in. As long as it's a slow flash, and it doesn't happen after you fly, or worse, when you fly, you will be fine.
The end points on the rudder, you know you have it right if the slider goes all the way to each end without binding. If it binds or doesn't reach the end of travel, then you need to do it again.
The governor needs to be OFF. There is no reason to run one on an electric heli, especially when it was made to work with all of the electronics it came with.
Just make sure your training gear is on good and the skids are up off the ground, spool up slow and take your time. Make sure you have an open area and if there is grass, make sure it's mowed very short. Starting out it's best to start out in a parking lot or the like. If you click on the articles button above, I have a how to fly series that shows step by step what you should do. It worked for me so I thought I would make videos on it.
