Mixing arms? Isn't your heli a FBL heli? If so, then you dont' have mixing arms. Are you talking about the swash drivers (metal arms) or the radius arms (plastic pieces that snap to the swash)? If the metal arms are backwards, it will just put a severe angle on the radius arms. If you put the radius arms on backwards, then that will throw off your swash phasing by a LOT. Both ways need to be corrected. The metal arms should CROSS the head block, and the radius arms should PUSH the swash (I think, double check this with teh manual). Hope this helps.
Already went back to the manual when I realized this wasn't right. It was the metal arms and the plastic ones atached to them, Mine were assembled that far when i ot them so there was one less step in messing it up. anyway, they are right now. I have gears coming in the morning so hiopefully I can get this thing in the air tomorrow. I am going to go through the BeastX again just to check everything now that I have been through it once and kind of know what is coming. I am generally up by 2 am so I can futz around in the shop all I want and tinker on things like that. People used to get all worked up when I fired up my late models in the midle of the night to check timing or jetting. I can get away with lots more with this electric Rc stuff!
