Lots of practice to make it muscle memory... and it takes a lot of practice to get there. Most transmitters have a center stick beep that you can enable, that lets you know when you hit center stick. I personally never used it, but it may help....if you can put up with the beep every time you hit center stick.How cognizant are you guys of where your sticks are? If the throttle stick was at mid-stick are you guys cognizant of that? Is that just practice to get to that point?
I even stripped the upgrade gears on the one I had. Did it in flight four times, doing tictocs and hurricanes. I finally got tired of it, and gave the helicopter to a friend who loves the small ones.The only bad thing about the 130x is the plastic tail gears. They like to strip of you strike a gnat in the air lol. But they did come out with upgraded gears to combat this issue. I think @callsign4223 has done this upgrade to his, even though he never flies it![]()
Tik toks on 130x seriously? Tail never held well enough for tik toks for me and I even had the upgraded motor. I remember the servos burning up constantly. I had a love/hate relationship with that heli. It taught me a bunch but it had a lot of issues.I even stripped the upgrade gears on the one I had. Did it in flight four times, doing tictocs and hurricanes. I finally got tired of it, and gave the helicopter to a friend who loves the small ones.
The 2 blade 180cfx was discontinued the 3 blade is still going. The really need to implement rescue for that heli. I wouldn't mind picking one up that didn't have electronics. I'd stick a Spirit FBL controller in it. What servos did you have? metal geared servos or plastic?I have a 180 cfx. Get the oxy2 instead. Its not as small but its going to be supported. I think the 180cfx has been discontinued.
Every time I crashed the 180 I sinking almost $60 USD into it. The servos striped every crash, landing gear every 3 or 4 crashes, tail gears every crash and if you missed throttle hold it cost you a main gear every time (then again that's any heli). Not to mention main shaft and spindle shafts. I have a plethora of parts because I needed it for it.
Now Once I start crashing the oxy2 ill let you know how bad it is in a crash.
Should maybe consider Spirit FBL controller? Has rescue flies fairly well and is reasonably priced.I may switch the oxy 2 over to spektrum and run a micro vortex or ikon
I changed the tail servo on mine. It was a micro heli servo and mount, to put the servo on the tail boom. That solved the tail issue, but the gears still sucked.Tik toks on 130x seriously? Tail never held well enough for tik toks for me and I even had the upgraded motor. I remember the servos burning up constantly. I had a love/hate relationship with that heli. It taught me a bunch but it had a lot of issues.
I suspect the Lynx LX1436 main gear would solve the stripped main gear problem. When I had a 300x was same issue stripped every crash. Once switch to the lynx main gear many many many crashes it never stripped.
These guys make quality parts for the micro helis. I'd try out one of their main shafts much better than blades.
Xtreme Production Official Web Site, RC Helicopters Parts for Helicopters Accessory
The Oxy2 I have heard good things about. I do not have one so can not give any kind of advice on that heli. Having the oxy3 its to close in size and if I was in the market for a micro I'd probably skip the oxy2. If I were to buy again I might buy an oxy2 over and oxy 3 though. I had a ton of left over parts from the 300x which led me to buy the oxy 3.
