OK, now I understand,Found an answer on your Magic 6° there is nothing Magic about it it could have been any known angle, it is simply a reference point the MICROBEAST PLUS uses to Teach the cyclic head geometry the pitch ratio.
Much appreciated,
I have my ESC startup to soft, so jumping from - zero to 65 is OK?
Cheers
You inserted this feedback here, not where you told me what throttle curve to set up.
Never mind, I will find it
Much appreciated,
Cheers
Alex I learned to hover on a simm and then went to a heli a 450 but 600 would be easier if money is no problem. I used 0-25-50-75-100 on throttle and pitch curves and it worked for me. A blae 330x rtf is already set up just charge batt. bind and go. and they real well.Much appreciated,
Cheers
