Guess this is the closest topic that batteries fit in.
Just finished flying my heli and a thought came to mind as I removed the warm battery. Are there heat sinks available for batteries?
Using an aluminum channel with velcro to mount to the heli and to set the battery in would add a bit of weight depending on the thickness of the alum.. The fit would have to be fairly close for good heat transfer. Another thought is a flat piece of alum. with fins to sit on top of the battery and held in place with the battery hold down strap.
This is a project for all you home workshop machinests. If anyone comes up with one I'll take one for a 3S battery.
