Well I got a new bird last week. After watching several flights at the field near work, I had to contact NitroPlanes and buy myself the Neptune EDF wing.
http://www.nitroplanes.com/02a-101-neptune-epo-blue-arf.html
Not much of a build on this baby. Gluing the two wings to the fuse, and then gluing on a few winglets. That's it!
My first EDF, first Elaron (sp?) controlled plane.
One of the mods needed on this bird is getting the ESC out of the canopy and into the fresh air. I opted to trim away a bit of the fuse behind the canopy. This allowed the ESC to drop in almost flush with the fuse and have the heatsink right where the intake to the EDF is. This also allowed me to shorten the motor wiring by about 4 inches. The bit of tape on the bottom is the COG point. This plane is very forgiving in exact COG placement.
I give you the actual Maiden Flight, cut short due to camera battery dying on me. Timer set to 6 minutes, but with the amount of deadsticking this plane can fly through will certainly yield at least 10 minute flight times.
[video=youtube_share;ZtDEfSGTy9M]http://youtu.be/ZtDEfSGTy9M[/video]
On the third battery I had the right servo fail on me. I figured it out to be my fault. Over driving the servo with more than 100% throws in Elevator and Aileron. Upon failure the bird lifted its left wing and headed towards the earth.
Knocked off each wing and ejected the battery with velcro and plastic support. All due to lack of glue, which helped dissipate some of the energy. No damage to any foam. Just a re-glue and go.
While I had it on the bench, I took the time to airbrush some orientation marks on the underbelly. Basically the underside of the canopy pod, and the underside of the wingtips FastBlack.
Tossed it back in the air before the Bears game. Winds at a constant 15 MPH. This bird hardly noticed it.
Sorry the flight goes out of frame at times. It is a blast to fly. And the slow passes are truly a thing of beauty.
[video=youtube_share;P25h8g1mvjk]http://youtu.be/P25h8g1mvjk[/video]
I have a feeling this could be a nice FPV platform.
