Graham Lawrie
I have been working on an issue with my Trex 600 tail.I found the braing had moved on the torque tube rubber housing, easy fix.
I then found play in the tail rotor bearings. I changed one side and the thrust bearings. On removing the other i found the main issue was a bearing in the early stages of failure.
I removed one no problem, the other broke up on removal. This is where my issue now lies. The outer race that is an interferance fit in the rotor arm is stuck solid. Due to the small od (10mm) it is hard to remove. I have ordered a new one, but i will not be beat with the removal of the outer bearing and then use this one as a spare
I have tried heating the arm with a soldering iron, but due to the size and conductivity of heat of the aluminium, the co-efficient of linear expansion does not allow the race to free itself
(Heats up to quick).
I am now going to try and freeze it. Hopefully this will work.
Any other methods feel free to let me know.
In normal working situations i run weld on the outer race and the heat contracts the bearing and it drops out.
Cant do that here so............
