Westy
LEGEND
your Normal settings are way to low.......
you need to match your upper half of your normal curve to your ID1 curve or you will find that when you switch from Normal to ID1 .... you will CLIMB fast..... and wehn you switch out of ID1 when you come into land ... it will drop like a stone due to at mid stick you have 50% throttle on normal and 75% on ID1 ....
Just sayin..... thats all - I have had that happen to me when I did not have a grasp on how it all worked. You want a smooth transition to ID1 and not have to make throttle/pitch adjustments to compensate
