If i had hair, i would pull it out by now! My AR7200BX on setup "J" can't match blue light and 6 degrees, no matter what i do. Swash plate linkage suppose to be 33 mm with my old servos, worked fine but with my new servos i can't get it to match up 6 degrees with the blue light. I can get close to 6 degrees like 7.3 but not 6. I tried shorting the linkage and increasing linkage and still no match. I haven't change anything beside old servo for new. Everything Zero out/90 degree on servo arms/ swash level, I'm really not sure what to do beside wipe the RX clean and start over. I would appreciate any input and if this helps, my bird is:
1) Tarot 450 Pro/DFC
2) Spektrum DX6i
3) AR7200BX
4)CC Talon 35a
5) Turnigy H2218 3550 KV motor
6) Align cyclic servos "DS416"
7) Align tail servo "DS425"
2) Spektrum DX6i
3) AR7200BX
4)CC Talon 35a
