stokke
Sundays, gotta love'em!
Woke up today, got in the shower, stuffed down a loaf of bread and sat right down at the "build station"![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Continued the wiring today.
As you can see, I have not followed along completely with the instructions (or Tony's video's for that matter).
I left out mounting the 3GX-unit so I'm able to set the connectors before actually mounting the 3GX in place.
I believe this spares me much trouble, and would advise this method to everyone mounting a 3GX-unit or a receiver for that matter.
Unit in place with double sided tape.
Wiring nearing completion. Only the wires from 3GX to RX to go.
Before mounting the Receiver I made sure the connection with my transmitter still was OK. It was!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Feels good to add this model to the Tx![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Fastened the Rx with more of that thick double-sided tape I got yesterday.
Rx mounted.
Satellite mounting.
Wiring complete.
Almost forgot to attach the links for aileron and pitch. LOL
Along with the great tape i bought yesterday, I also got some Velcro to use for by battery mounting.
Since I have used a zip-tie on the ESC, I went ahead and fitted one Velcro-piece above, and one under to make sure the battery sits flush along the bracket.
Battery in place with strap. That strap which was included with the kit barely is long enough to reach around the battery. I think I will replace the strap at a later point with a longer one.
Canopy rubber mounts.
OMG! OMG! OMG! Feeling like a kid again!!
Put on the blades. I see the nuts provided are some sort of lock-nuts, but I added some thread lock anyway.
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET!
New and old.
After a short solo celebration, I removed the canopy and proceeded to power up the electronics. Put the 3GX in so-called "DIR-mode" (Direct control mode, controls not affected by the 3GX system). This is achieved with holding the small button on the device while connecting the battery.
I had to reverse the aileron-servo, after that the swash responded correctly to my stick input.
I noticed at mid sticks, the rudder pitch slider is not centered. I'm not sure if this is correct, please advise on this.
I also put on my pitch gauge, and the pitch is way off. I had about -20 degrees on low throttle, and about +9 degrees on high.
Also at mid stick, the swash is clearly not level.
I will now commence to research the setting up of the swash and head, but any input on all of this will be much appreciated!
I'll come back with another update later tonight.
Rx mounted.
Satellite mounting.
Wiring complete.
New and old.
