The only real thing you need to do is to set your satellite under the config tab to 2048 (they say 1024, but even mine went nuts. Set it to 2048). Make sure serial Rx is turned on under ports on uart 3 and you should be golden.
wire your motors nice and purdy! Straight wires. with these ESC's, you can reverse them in the BLHeli Suit or whatever it is called. I had to reverse every single one of mine lmao.
