I really like this plane, but would like it to be more floaty, so I'm thinking of a slightly bigger one.
I tried to put the tiled pdf plans together using inkscape, but there were some issues with that.
I'd really like to play with the dimensions to make an iteration to my taste.
Will of course share here if it turns out any good.
I'm looking at a target wing span of 100 cm (the foam board available in Sweden is 100x70 cm and a bit more dense than the Dollar Tree variety).
Tweaking print scaling options could achieve this, but I'd like some more control.
So, is there an untiled plan available, or even the original drawing?
