Re: Can Someone PLEASE help me with the Mixes for Throttle, pitch elevator and ailero
SO.... I started the engine. but not that easy..
My electric starter shaft sits on the starter with a rubber sleeve. Well.. I stripped that sleeve when I was applying too much pressure on it. So when i was hooking it to the heli, it was slipping now. making the clutch and the fan to go in oscillatory motion rather than circular, because i didnt have enough friction
Well.. that happened a couple of times, then I finaly stuffed a rubber around the starter long shaft in my electric starter, and then pushed the rod in and hooked it to the heli. well.. my heli started.. It was bit higher rpm than expected. my clutch was engaging, and blades wanted to move, but as I had set the idle position on the carb low enough it was very slow but steady. So i trimmed my pot on TX down like 3-4 clicks and I was OK..
engine was running.. I didnt let it heat up i think or may be it was too rich / lean ( i donno) i pumped just a wee bit of throttle into it, and it died on me..
well.. i brought the starter back out.. wanted to starterd, but all of a sudden.. WIERD noises.. like something grinding with something. I STOPPED immediately. unhooked everything. tried turning the heli shaft with hand.. the engine and fan seem disconnected.. ohh well..
I think that oscillatory motion made my fan and clutch to come loose. I am HOPING with crossed fingers, when i open it tonight, I find only a a open nut and I screw it back down to get it all OK again. I am really really hoping.. The engine "seems" fine. But I will try to turn it with my hand, and see if it is ok. my bet is its ok. its something somewhere on the top.
well i know you guys would be dissappointed in me.. lol .. haha.. but i really tried and started the engine. this was just my past mistakes firing back at me. I have an extra sleeve in arlington(i am in plano) I will get that on saturday or something. but, till then.. I am gonna open it and update you guys.. The heli sounds beautiful though.. i think i am getting over the sound of the idling engine to start with..
FINGER CROSSED!! :
