danhampson
fixed it it was the brain/ikon software.
what ive had to do was connect the heli to computer and in the software check that i had 0% at low stick and 100% at high stick, turn everything off.
Turn tx on, put the throttle to mid stick and power up the heli and run the ikon software.
In the ikon software go to advanced setup/common/governor, move the throttle to the high position on tx and then slowly move the throttle max slider very slowly up until the esc gives conformation tone.
Lower the throttle to 0 (tx) and move the low throttle slider (slowly) until you get another conformation tone.
Job done.
ive not enabled external gov on the esc as its set to fixed endpoints as standard, im waiting for my castle link to arrive. I will have a look at the stick programming for it later on.
Job done.
