Oh wow, I have some questions. I'll number them to, hopefully, make the responses easier.
1. To remove the motor from my Trex 600 Pro DFC, since the motor is mounted on the top of the motor mount (opposite of my 500e), I would actually have to remove the entire motor mount from the frame. Is this correct?
2. Setting the gear mesh. I have a slant main gear and pinion. The setup is very different from my Trex 500e. Since the motor is mounted on top of the motor mount, how is the gear mesh properly set?
3. Battery placement. I'm wanting to adhere the Velcro strips to the battery tray and to my 6s 3700mah lipo's. How would I find out where to mount the batteries on the battery tray for correct CG? Both lipo's, inline with each other, are longer than the battery tray is. It's a bit puzzling.
I think that's all that I have right now. This helicopter is just so much difference in comparison to my 500. There are many things that just blow my mind.
Thanks!
