Westy
LEGEND
I would have thought the key feature of the DX8 is the ability to import model files? ... well I amd sure someong here must have a running config that can be used as a base to speed up the process and all that needs to be done is the sub trims and trims and end points all reset to std, then the swash revelled & CCPM endpoints done .... should only take about 10 minutes since everything is done.
and of course re check your 0 pitch ... and pitch range (may need your swash raising or lowering....
